Looking for Staff Members
Quick question I made my mod and am curious why is it that every time a change my oil theres alot of gases or at least thats what I think I can smell the hot amsoil oil and see the vapors coming form the bottom of the truck when am at light. So is it normal ?
  • Replies 5
  • Views 2.4k
All is well,its normal because of the vent tube pumping out the gases. There are threads on how to extend the vent pipe. The smell will go away after a few hundred miles. I will be doing my '03 this winter,can't stand the smell.
i quit using rotella because of the smell and went to pre. blue by valvoline 15w40 recommeded and endorsed by the big "C":thumbup2:so..amsoil has an odor huh?
You are right on the button. I have the free "Life time oil changes" from my local stealership and all they use is the Rotella. It takes a good 500+ miles before it ALMOST goes away. Even with 5K miles and I work the truck hard or drive a long distance and then do some in town driving,stop light to stop light I get a wif of it. A friend uses Delo 400 syn in his 2000 Ram and he doesn't get the smell since he switched. I would switch myself,but the free oil and filter change is hard to pass up. Even at only 1 oil change a year.:woot:
