- Replies 3
- Views 912
jlwelding 1 post
Silverwolf2691 1 post
Max Tune 1 post
Popular Days
Define backed off the adjuster 3 times? If you mean just 3 screw driver movements (lack of a better phrase), you probably haven't even rotated the star wheel a full revolution. If you mean full back o
Backed off in Texas is 6or7 rounds each time. Anyhow, I got it figured out. I bought these calipers two months ago and the driver side was sticking first test drive down the block, got it replaced and
problem with my 2002. The ebrake is dragging. The left side is 135-150 and the right side is 235 and as high as 280. I am pulling my hair out over this one, I backed off the adjuster 3 times now and no temp change. I backed off the cable adjuster till I only have about 2 inches of ebrake pedal from the floor. I pushed the arms that the cable is attached to back on the hubs, helping the spring in other words. Go down the road and no change. This is insane, the brake disk on the inside is 109 but when you shoot the ebrake hub its 200 plus, the caliper is 97-109, the hub where the outer bearing is 90 degrees. I take my temp gun and shoot between the rim and the brake disk.
