Grinding noise under hood in park.
- Replies 2
- Views 1.2k
Mopar1973Man 1 post
Max Tune 1 post
Popular Days
Take belt off and try again. If noise goes away, check for bad bearing somewhere.... Also check to make sure your starter isn't staying engaged....
I replaced my ECM and FCM plugs with pigtailed aftermarket plugs. When I started the truck it idled normally but when i pressed the accelerator there was a loud grinding noise under the hood. What could I have done to cause this?
It sat for over a month before I made the repair.
Disconnected batteries first.
Spliced wires one at a time.
Reset throttle sensor before starting.
No codes.
