Hello from California
- Replies 35
- Views 8k
I agree. I currently have 370,000 miles on the OEM head gasket with running a mild tune for the last 100,000 miles. No studs. The truck has done its share of heavy hauling (up to 21,000 lbs gross c
Welcome to the family... Sorry I'm late to the party here but life has been keeping me hoping these days and busy. Just consider I'm running +150 HP injectors (7 x 0.010) and stock HX35W
Dennis, welcome to the forum. Turbos are usually pretty bullet proof. Could you elaborate a bit more on "the turbo started acting up"? - John
Hello, I'm Dennis. I'm the original owner of my 2001 2500 quad cab long bed 4x4. It's currently stock except for the air filter, fass, smarty. The auto was rebuilt a few years ago planning on futures mods. 3.55 and with 3rd gen brakes, wheels and 265/70/17 tires. About 150k on the clock. Last trip towing my travel trailer (about 10k lbs), the turbo started acting up. That means upgrade time. I've paid the piper and now have a log list of parts on the way. Mostly from DAP. My plan is to do these upgrades in 4-5 install stages.
Stage 1, Exhaust manifold and HX35 62/64/12 turbo
Stage 2, Quad Adrenaline and gauges (gonna use an old ipad for them)
Stage 3, 100hp injectors, head studs and valve lash adjust/correction. I probably don't need the studs, but I'm in there.
Stage 4, Fleece Sureflo, redo lines from tank to fass to vp. Thinking about eliminating the canister, but I'm unsure if it will create problems/codes. Looking forward to having a working fuel gauge again. I might switch stage 3 and 4 around.
Stage 5, All the little things that have been neglected over the years. New drivers seat cover/cushion, new hood insulation, new grill...
The old girl is mostly just a work horse. Not getting near as much attention as she deserves. Four or five trips a year plus hardware store and dump runs. I recently turned down the opportunity to buy my brother in law's 2016 3500 4x4 limited long bed. I've loved his truck since he took delivery on it. That's pretty much what spurred on these upgrades. 40k for a used truck with 125k on it, or give the old girl some lovin. So here I am
Kind regards
Dennis
