Intermittent rough idle/running in general
- Replies 3
- Views 1.2k
Threadzy 2 posts
YeaImDylan 1 post
Hey all, back again for some advice.
Truck when cold upon startup seems to run the best and once she's up to temp, I seem to get more vibration than I should. Truck isn't stock and I've been told it won't run AS smooth as a stock truck would since she has bigger injectors and a different pump. I noticed today and the other day that I was getting a lot of vibration when driving, like the engine was running rough. Yesterday she ran a lot better but only recently have I noticed the roughness and it's at random. Sometime last week I remember pulling in to park her after going out in town and I was like damn, she's pretty smooth (up to temp too etc) and it'll randomly change. I do know I have somewhat bad battery cables, especially a shitty ground... Can bad electrical connections on these trucks cause them to intermittently run rough? Currently only have one battery and I have a new set of cables (hoping I ordered enough feet for the crossover
) but need a passenger battery tray so I can install everything all at once and have a full electrical system... Somewhat skeptical one what to do with grounds that should be on that side where the battery was removed... Maybe previous owner did the W-T Ground mod or something similar?
Also, anyone with DAP 150's have a lot of haze even when hot? In the right light I feel it's bad and it scares me... Honestly I hope its just the hotrod vp going out and that's what's causing it. Injectors are only maybe 6mo old.. No blue tint it seems to the haze so I don't think my new turbo has seals that are already going.. Just starting to be at a dead end with the truck and it worries me lol
