Full Send Diesel Temp control trans pan
- Replies 4
- Views 2.1k
Mopar1973Man 1 post
Sycostang67 1 post
LorenS 1 post
Hutch24v 1 post
I was casually looking for a transmission line kit and came across this fancy transmission pan. It allows you to bypass the heat exchanger, it has fittings in the pan to run engine coolant. It looks like it could eliminate the possibility of making a large milk shake should the factory exchanger fail. It's not cheap but it has me rubbing my chin and going Hmmmm.
Edited by Sycostang67
