Oxygen sensor issue with aftermarket cats
- Replies 3
- Views 4.8k
Mopar1973Man 1 post
IBMobile 1 post
Tatted Hemi 1 post
Popular Days
The codes were P0420 and P0430? I've had the same codes on other cars and fix them by using spark plug non-foulers. Drill the inside of one non-fouler to just over ½ inch so that the rear O² sensor
Just to explain a bit... The first 02 sensor is going to create a mild lean rich sine-wave of signal. This is normal it will go rich and then lean and back to rich and continues. Now the downstream O2
Installing aftermarket catalytic converters may trip a check catalyst below threshold code or a rich to lean code in these cars depending on the brand you bought. These motors are very sensitive. I bought a set of BBK high flows and had this issue and it took me forever to track down a simple enough remedy so I thought I might share my findings here. With the purchase of these cats I later found big daddy's garage has an o2 CEL fix. It's a cat simulator that threads between the downstream o2 sensors and your exhaust. Bought 2 at 50 bucks a pop and cleared the code without issue. Still saved me money as opposed to purchasing the higher end high flow cats as it was out of my budget at the time. These are for a racing application and not street legal in most states from what I've researched but they are great for track days getting rid of that pesky check engine light if it's a bother to you. I paired this with my borla atak cat back exhaust and a set of long tube headers and definitely make great sound and mean tone with the set up. Let me know if you have questions pertaining to hemi exhaust system set ups.
