- Replies 58
- Views 6k
Unreal Summit 25 posts
Mopar1973Man 12 posts
Andyba20 7 posts
LorenS 5 posts
That's super helpful too! This sire's always been a huge help! You have as well!
Test MAP sensor Remove MAP sensor. With a multimeter set for 20 volts DC and ignition key on test orange wire at pin A of MAP sensor for 5 volts. With a multimeter set for 20 vol
Thank you
So yesterday morning I went to start my dodge for the first time in over a week. Let the grid heater cycle 2 times and tried to start it. Wouldn't start so I unhooked the quad from the battery but not the map (forgot that part). Jumped the truck and had a cel. Drove to my brother's next door to change the turbo. Got that done and went for a drive. Had zero boost checked the cel and it was a p0238, 0236.
Unhooked the quad at the plug, left the quad map sensor is plugged and same results. Drove like a turd and no boost. (Limp mode if I can describe it).
Did I fry the map or the quad? Should I unhook the quad map sensor and plug in the factory one?
Thanks!
