Lifter Inspection Cover Leak
Im starting the project today and checking in to see if there is a preference on what gasket maker to go with as Id like to make this a one time deal. Thanks
Edited by jlwelding
  • Replies 7
  • Views 1.9k
    NAPA gasket is all I ever used.    Now make sure your cover isn't warped and that there is no issues. Do NOT use silicone on the cover or gasket. I just slip the new gasket on making sure th
  • The million dollar question is who use's the thicker washers and who doesn't? Ten years ago they didnt come with the set and I never had a leak.
    My last gasket I installed I just used the factory bolts over again. No issues.
Now make sure your cover isn't warped and that there is no issues. Do NOT use silicone on the cover or gasket. I just slip the new gasket on making sure that its facing the right direction typically there is a tab showing direction. Then tighten the bolts as usual and reassmeble the VP44 into the gear case.
Well dorman makes napa and from everything I searched its on backorder till February 10th. I can get Felpro, any bad reports on felpro lately?
I would use FelPro or Mahle gaskets over any Cummins gasket any day. Just a heads up Cummins does not produce gaskets like the head gasket is produced in China by BLK.
The felpro also came with 1/4 inch thick steel washers with rubber backing along with the thin washers that go behind the bolts. I guess they are for extra cover support.
This gasket came with thick washers with rubber seals. I get their idea of pulling it down tighter but I think it will warp the tin cover. Its new to me thats why I asked. Im just going back with new gasket and the old bolts.
