Cyl injector lines loosening up over time- is there a torque spec?
- Replies 5
- Views 2.7k
Mopar1973Man 2 posts
Hutch24v 2 posts
Tractorman 1 post
Popular Days
I believe 28 ft/lbs is the magic number for the fuel line connection at the head. I have never experienced any injector lines coming loose. - John
You be correct... I just look in the Dodge FSM to verify...
BTW after investigating it was cylinder #2 that was seeping fuel. Removed the intake horn/grid heater and the fuel line was way loose at the head. Can't believe I didn't tighten this down properly. I
Anyone else experience a loosening of fuel injector lines over time? I just started to smell some diesel fuel in/around the cabin and checked the lines to the head and saw some droplets around the injectors on the intake plate. Checked the tightness of some of the injectors and some weren't snugged all the way. I can only think they've loosened up over time due to general engine vibration but surprised that they did. Is there even a reqd torque spec on these? Thought they just had to be good and snug.
Thanks
Mark
