Having my VP44 Rebuilt versus reman/exchange
- Replies 7
- Views 2.4k
Mopar1973Man 3 posts
VMac822 3 posts
LorenS 1 post
Popular Days
So I ended up getting a cheap core VP44 and bought an off the shelf rebuilt from Advanced Diesel in Spokane. They said they have the Bosch 815 test stand and they run them in and have a 3 year warran
Revision 027 pumps if built at a Certified Bosch should come with... Timing piston sleeve is steel. New PSG All moving parts replaced. Ran on a Bosch 815 test stand for 3 h
For example Blue Chip is not a certified rebuilder. PSG is used Moving parts are replaced Not ran on a test stand and calibrated
I was wondering if anyone has sent their VP44 out to be refreshed/rebuilt versus doing the typical purchase of a rebuilt unit and sending the old one in as a core. The pump on my truck has basically been running fine for 130K miles even though it was a reman of unknown origin installed by the previous owner in 2011. I thought it would be interesting to have whatever shop rebuild mine and send it back and let me know what it looked like at teardown. . .is my filtration working effectively, does it show signs of low quality fuel, was the timing piston scored, etc.
I have been having an odd starting issue intermittently for about 4 yrs/50k miles where sometimes it won't fire when cranking. The solution is to turn the key off and try again, it usually fires instantly. It doesn't matter if it's cold or hot start, if it's sat for days or 10 seconds. I believe my fuel system is sound with Fuelab 100 lift pump and spinon 7 micron filter and consistent 13-18 psi pressure, fed from a Beans under-tank pickup. Other than that the truck runs good and gets good fuel economy.
Has anyone done business directly with any of the Bosch certified shops Michael listed in this post?
