- Replies 6
- Views 1.5k
Mopar1973Man 2 posts
Tractorman 2 posts
Thr333_Arr0ws 2 posts
Popular Days
I am not going to be of much help here, but can you describe the above in more detail? Is this a rapid change in rpm - such as, 2 or 3 times per second? Or, is this a much slower change?
Yeah injectors only last up to 100k miles. Typically pop pressures tend to fall off and spray isn't as good. The only injectors I will buy is non-Bosch injectors which custom built and bee
@Thr333_Arr0ws, it may be that nothing is wrong. The following is only my thoughts, but it would seem to me that the ECM easily has the capabilities of operating stock injectors smoothly through all
Good evening all,
Huge fan of this forum, it's taught me a lot about working on my truck and I'm hoping I can get some help pinpointing a problem.
I've got a 99 24V 4WD with an NV4500 5 spd manual transmission, about 325K miles, bought it about 4 years ago with 272K miles. Over the last weekend I replaced the injectors with some Bosch 75hp, I replaced the crossover tubes with new ones while I was in there, all with new o-rings and new copper washers, and I also adjusted the valves. Followed torque procedure when putting everything back together. Before this was done the truck was pretty sluggish with acceleration and building turbo pressure. Now she accelerates great and builds pressure no issues, but I'm experiencing what feels like a stalling or lope issue when I come to a stop and push the clutch in. Engine sounds like it revs down and then up and then down and then up again before returning to a normal idle. It didn't do this before replacing the injectors and tubes. VP44 is fairly new, maybe 20K miles on it, lift pump is a Fass.
The previous owner kept a log of everything done to the truck since mid 2014, I've kept up that tradition.
Is this normal after upgrading injectors, or is it something I need to diagnose and repair? Thanks!
