Auxiliary Fan Switch
I decided to ditch the thermostatic switch on my auxiliary trans cooler with fan and wire a switch into the cab instead. I got cute and ordered a push button switch with a fan symbol and blue LED backlighting. Can anybody tell me (or draw on a napkin) the best best way to wire this to a relay? Should I be using a standard Bosch 5 pin relay or something different. The wires in the pic are as follows:
Black-negative
Green-closed
White- normally open
Blue- normally closed
Red-positive
  • Replies 8
  • Views 2.4k
  • Great work!
    Great work!
    I see @IBMobile already helped you.    Here is another drawing that may help.
  • Red to battery power and terminal 30 Black to terminal 85 and ground White to terminal 86 Signal wire for fan motor relay to terminal 87  Do not use green and blue wire This w
  • Should work fine .  That's why there is a ground wire on the switch.  You can always make a mock set up to test on the bench with a 12V power supply, a 12V battery will work. Test it before mounting i
This will be a low amperage circuit used to energize a higher amperage relay used for the fan motor.
589cf003d48b2_5-pin-automotive-type-12volt-40-amp-relay-with-diode-protection-alt-ry18-3-2542-p1.jpg.478e888b891f55623e725f1f7ed6a7ba.jpgRe
My man @IBMobile I knew you’d know how this should work. Thanks so much.
Btw, ignoring the blue and green wires won’t affect the led lighting? The rudimentary drawings that came with the switch showed several wiring configurations and I was trying to use the one that when the the switch was pushed in, turned on the fan and the LED backlight, then when pushed again turned the fan and light off.
Should work fine .  That's why there is a ground wire on the switch.  You can always make a mock set up to test on the bench with a 12V power supply, a 12V battery will work. Test it before mounting it in the truck.
I think I’ll take your advice and do a mock up in the garage. Does this look ok?IMG_4429.jpeg.715cd90c049a40529791b89b4a8d5648.jpeg
You’re always coming into these discussions with really helpful stuff @Great work! thanks a ton!
If it was me I would buy a ISSPro EV2 Transmission Temperature gauge, ISSPro EV2 programming cable and then the optional relay addon. Now Hook up the ISSPro as usual with the temperature probe in the pan of the transmission. Now I would program the transmission temp warning light for 220 or so. I would set the optional relay for say 160 degree. So now that relay will turn on the cooling fan for your transmission cooler. Being programable you can adjust your fan on and off times and so forth. So now your transmission temperature gauge controls the fan for you. Totally programmable!
