- Replies 13
- Views 1.3k
01_Cummins_4x4 5 posts
Mopar1973Man 4 posts
IBMobile 4 posts
Your door switch wire colors are correct with the black/light green wire at both doors going to ground.
There is 12V at the door pins. The interior lights are power by the IOD fuse in the cab then pink wire runs to all lights the the ground leg which is the wire color that mentioned by @IBMobile that is
Which wire has 12V at the door pins (switch)? The way I read the wire diagram in the FSM, pages: 8W-44-3,4,5 and 8W-45-10, the switches ground the CTM and headlight switch.
I bought a set of brand new 3rd gen Dodge AMP Research Power Steps and the Tyca Industries 2nd gen conversion kit to mount them on my 01.
The magnetic switches that come with the Tyca conversion kit was wired as instructed - solid purple to left door magnetic switch, and purple/yellow to right door magnetic switch, and then the 2nd wires from each magnetic switch went to a known good ground. Neither step is working from them, so I pulled those POS magnetic switches out.
For the 3rd Gen Dodges, they use a posi-loc terminal to tap into each door ajar switch at each door - solid purple for left front door, purple/grey for left rear door, purple/yellow for right front door, and purple/white for right rear door.
The instructions state that the steps are looking for a "ground" signal to make them work.
According to the 01 Dodge ram manual, the left door ajar switch has a tan, white, and black/green wires on that side, with the black/green being the ground wire. Is that correct?
It states that the passenger side door has a black/light blue wire, and the black/green wire is the ground wire for that side as well.
