PO1690 and PO336 codes
- Replies 4
- Views 1.6k
coyote 2 posts
Mopar1973Man 1 post
Great work! 1 post
I have a 1999 dodge ram 2500 5 sp manual. We have a perplexing problem. I`ve had over the last year a code of 1698 and Crank position sensor code PO336 thrown. The truck started having a hiccup when idling and the tach would drop off and come back and check engine light coming on. Eventually the truck wouldn`t start at all. My electrical mechanic replaced several relevant pins on the plug to the ECM then replaced the connector on the VP44. Previous to that we put a rebuilt ECM on. What he thinks is there`s a timing issue with the crank position sensor and the VP44. The truck starts and runs but is throwing these codes most of the time now. I`ve heard tone ring?, Key on the VP44. Any ideas on what could be causing this?? Thanks , Denise
