Parma ID & Jobs
Anyone in the Boise area wants to meet up with me? I'm staying in Parma at a friend's place with my RV.  Even got Thor all loaded up with tools and willing to meet up with other forum members.
I'm down in the southwest Idaho doing Cummins work. I've got a return of a client with a 98 12V Cummins. Yeah there is a total of 4.8A draw on this truck and it's in several circuits. Instrument cluster, PCM, trailer brake controller, hazards, and integrated module (similar to the central timer).
Already got the 35 inch tires off for 285s. Replaced the wasted front rotors and brake pads. I've got the A/C working and vacuum lone issues fixed.
  • Replies 7
  • Views 2.3k
    Pulling the 2 inch leveling kit today get it done to stock rake once again another truck with 35 inch tires on 3.55 gear which the owner opted for 285s on the 17 wheels. Make this truck run right.
  • Sycostang67
    Sycostang67
    I think I got everything while I was at work today.  I’ll  text you on Sunday and get the address from you.   I haven’t been out there since you reset my speedometer for the big mud tires I used to ru
I do this more than you think. Removing lift kits.
Sure I could @Sycostang67. Make sure you get the ring terminals and maybe a roll of electrical tape. I'll do the W-T mod for you and that one bolt which is listed in the article. I'm sure you know where I'm staying at already?
Sweet, will you be around until Sunday?  I assume you’re out at Muddys place, I would need the address again.  I’ll read through the article again and grab the other pieces.
Yup, I'm out here. Yeah, gather up all the stuff for the W-T Mod. I've done them typically in about 2 hours.
I think I got everything while I was at work today.  I’ll  text you on Sunday and get the address from you.   I haven’t been out there since you reset my speedometer for the big mud tires I used to run.
You should have my number give me a shout and we can finalize this even more.
