- Replies 6
- Views 7.2k
Ravewolf 3 posts
Tractorman 2 posts
Mopar1973Man 1 post
So I was given a 92 gmc sierra 1500 with a 4.3l. I've recently been trying to get the a/c going but have been having hell.
When I first did anything with it, I just recharged it and got the compressor to spin but it wasn't blowing anything. So I suspected either the orifice tube was clogged or the compressor was junk. I ended up having to buy another line and condenser because the threads on the orifice tube line were galled and stripped.
After I did that, I recharged the system and added about 1.5oz of oil to the system, and it was working beautifully until the compressor suddenly started grinding really bad, and it stopped blowing cold. I figured it gave up the ghost.
I then ordered a new compressor, new condenser, and a new filter-drier. I flushed the crap out of the evaporater core, and the lines. I then added 5oz of oil to the system (compressor came with 3oz already), spun the new compressor ten times, put a vacuum to it for an hour, and slowly put two cans of refrigerant in. Worked beautifully again, but then the compressor wouldn't shut off. Then it started grinding. Then something popped really loud like a prv.
I haven't touched the truck since, because I'm not sure if I fried the new compressor or not.
Idk what I've done wrong this time. I did everything I could think of, including using almost all new components. And when I say I flushed the evaporater core, I mean I flushed it. I used a/c system flush, and when I ran out, used 95% alcohol to flush it. Then pushed compressed air through it until nothing came out.
I did pour the oil into the hotside via the suction manifold off the back of the compressor. Then spun it to make sure it didn't pool up (if that's a thing?)
Idk if anyone is an a/c tech on here, or has links to some good guides. I'm a diyer, so I have my own vacuum pump and a/c manifold, along with a flush gun, and other tools. But I'm shaky at best when it comes to a/c stuff. Thanks for any help/tips/admonishments
