Aux Lighting and Negative Switching Advice
- Replies 5
- Views 2.2k
Mopar1973Man 1 post
Royal Squire 1 post
Andyba20 1 post
QuadRunnerJake 1 post
I'm planning on adding some auxiliary lighting to my 98 & 1/2 2500 and while poking around under the hood I noticed that the existing fog lights (and presumably other lights) appear to use negative switching. For those who've been down this path before, do you think I should use negative switching for any new lighting or other accessories so that it's all the same? If so should I do this for the switches in the cab as well or just use positive switching at that point and use the relays under the hood to switch ground? I can do it either way but I have to admit that positive switching feels more natural to me. I'm just curious if either approach is likely to bite me in the butt later for some reason I haven't thought of.
