- Replies 9
- Views 1.2k
QuadRunnerJake 5 posts
Tractorman 3 posts
Great work! 1 post
P0122 (M) Throttle Position Sensor Voltage Low Throttle position sensor input below the acceptable voltage range. The "M" (Malfunction Indicator Lamp) may or may not light dependent on E
Do you have a delayed wait to start light. The high idle and delayed WTS is how my ECM started it's death.
I will get intermittent dead pedal when driving above say 60mph with light pedal pressure.. I also get this weird hanging up when revving the truck in neutral it will rev up just fine then hang up at say 2000rpm then come back down..all of the issues show up after some amount of highway driving.
Drives fine on short trips, long trips it's constantly cutting out at some point. The hanging up thing worries me that something mechanical is ****** up. How often does the control unit fail vs mechanical on newer units that have been fuel starved at some point?
I have a new fass 150 pump motor and so VP44 installed less than 10,000 miles ago. I did blow up the fass 8000 miles ago leaving me stranded and forcing me to limp the truck 30 miles. No real issues until the last 1000 miles or so.
Edited by QuadRunnerJake
Add info
