Oil pressure gauge intermittently working
- Replies 6
- Views 2k
Mopar1973Man 2 posts
Tractorman 2 posts
daav544 2 posts
Oil pressure gauge has intermittently been working for the past couple days, been working on start up then I'll start driving and it will randomly drop then come back alive. Seems like it likes to drop out more so when I come to a stop and the truck is idling with lower oil pressure. When I'm cruising and have like 40 psi it usually stays alive. If I come to a stop and it does while I'm sitting there idling I can rev and hold it at like 1100 then it magically comes back alive on the dash. Is this most likely the oil pressure sensor? Or could it be a bad ground somewhere? Sitting idling right now and it's jumping back and fourth check gauges light will come on it will drop to zero then come back alive then die again and so on, it's pretty annoying listening to the beeping constantly lol
