Power Steering Pump / Vacuum pump Conversion
- Replies 13
- Views 2.5k
Stanley 6 posts
Mace 4 posts
Tractorman 3 posts
Here are some threads to peruse that may offer some insight. I have performed both mods about 1 year ago - well worth my time and expense. John
I used a Standard Motor Products VCP112 electric vacuum pump for my application. It was less than $100 from Parts Geek. This vacuum pump regulates pressure from 13" HG to 15" HG and there is no flow
I purchased the Standard Motor Products vacuum pump - not sure about the quality. While performing these modifications, I also replaced my original vacuum operated exhaust brake (PacBrake) with an i
Most Helpful Posts
@mace, I have performed the power steering pump and vacuum pump conversion that you brought to this site. I hope you are still perusing the site and will see this.
The time and effort spent on this project (and the APPS relocate) has been very worthwhile. Much engine space has been freed up and the power steering reservoir is right where it should be for easy fluid check / fill. The reservoir is like the brake master cylinder reservoir – you can see the fluid level through the reservoir.
An unexpected benefit is that this direct mount power steering pump outperforms any previous power steering pump that has been on this truck. There is no more stopping of the steering wheel when the power steering is under high demand, such as when maneuvering in tight spaces, steering from stop to stop with little forward or backward movement of the truck.
I started the project by finding a location for the new power steering reservoir, which was going to be right where the APPS assembly used to be. Then I built a mounting bracket for the reservoir (shown below). The first part of the bracket assembly is designed to let the weight of the oil and reservoir rest in the V slot.
In the above photo, note the welded nut where the tab on the top of the reservoir is screwed into the bracket.
In the photos below, more brackets are added to fasten the unit to the engine.
Below is the new location for the reservoir in the engine compartment - lots of space available for mounting with the removal of the APPS and APPS mounting assembly.
I don't have any photos of the actual pump mount, but the mounting is straight forward, especially with the addition of studs instead of bolts. Much easier installation the old vacuum pump / power steering pump combination was. I didn't use a gasket - just the grey Permatex RTV gasket maker. The one thing that Mace did that I should have done (which he clearly mentioned) is to have the pump suction fitting turned down on a lathe from 22 mm to 19 mm to match the 19 mm connection on the reservoir. Because I didn't do that, I have not-so-neat connections from the pump suction to the reservoir (another reason to not take a photo down there).
@Mace, thank you again for making this possible.
That’s all, folks!
John
Edited by Tractorman
