Vp44 Injection Pump advice
- Replies 4
- Views 983
Tractorman 2 posts
IBMobile 1 post
RayNAz 1 post
Yesterday while on my way home from out of town, I had just finished filling up, the engine sounded "odd", louder and with a rattle. It sounded like my older Ford Diesel when started cold with the cold timing advance engaged. About 10 miles down the road I lost most power, felt like I had maybe 20% throttle available and the CEL came on. I pulled off but couldn't pull a code. It felt fine at low speed so I reset the CEL and continued on but the problem returned after a few miles on the freeway. I was eventually able to pull a P0216 code and I've read up on what that usually means. Ended up limping home at 45mph taking back roads when possible. I thought it could have been bad fuel but my last stop was at a high volume station and there really wasn't any water in the separator.
Do you folks agree that it's probably new VP44 time?
Does this look like a good choice? https://www.dieselautopower.com/bosch-027-vp44-fuel-injection-pump-standard-output-235hp-wire-tap-ok-1-year-warranty-vp44027tap-13584
