- Replies 2
- Views 709
Mopar1973Man 1 post
Mace 1 post
I thought I’d share my recent drivetrain upgrade I put in my 01’ 3500 (SRW converted) 6 spd.
On transfer case side of things swapping a NP271D in is pretty common for a 2nd gen. I wanted to take it one step farther.
It took some trial & error finding what parts will work and what doesn’t. It’s pretty much a modified Ford design.
I found a used 08’ NP271D and rebuilt/modified it. Eliminated the leaky Dodge slip yoke tail housing and utilized the rear fixed flange yoke setup from a 06’ NP273F.
I bought the rebuild kit, some updated parts & specific seal installers from TorqueKing4x4.
I also installed the Ford style companion flange on my Dana 80 along with a new washer, nut & seal.
***Snap-On # M3586 is the correct thin walled 1-7/8” socket if you ever need it.***
Initially had a 5” aluminum driveshaft but the Sonax slip yoke kit is quite expensive so I had a 4” steel one locally made and upsized it to 1480 greasable ujoints (OEM are 1410).
T/case fits perfectly. There’s 1/8” of clearance at the frame and no contact at bottom of cab.
The 2nd Gen linkage rod (11”) is a tad short so even set at max travel the shifter will be off just a touch. So I replaced it with the 3rd Gen 16” one and now it’s perfect.
I don’t have the cad Dana 60 so the momentary ball switch from the old NP241D-HD just swaps over to make the 4wd light come on.
I have the LRG trans crossmember so I didn’t have any interference with the front driveshaft.
APPS delete ✅
Midrange power steering ✅
Electric vacuum pump ✅
Next project: Dynatrac high pinion 35 spline Dana 60 3.73 gears with an electric locker…
Enjoy!
Edited by Mace
