Front lower shock bolt size
Hi
My front lower shock bolts have worn so shock bushings last 5 minutes before being shot.
Could someone be able to get me a price shipped to the UK please I can't find them on rock auto unfortunately.
Thanks
Or even the size/thread I could try and find something over here. Maybe cross over with a jeep or something
  • Replies 10
  • Views 1.1k
    Here is a trick for next time I found the bolt part number and also the bolt size... BOLT, Hex Flange Head, M14x2.00x80.00, Shock Mounting, Then go back to Google to look up the part... Then selec
  • The bolt has worn thin so the sleeve isn't tight around the bolt I fitted new shocks they started knocking a few weeks later. This was a few years ago now truck has been pretty much out of service unt
4x4
Then go back to Google to look up the part... Then select a supplier for the part. I see Amazon and a few others...
Thanks I will try order some through Amazon US
I am not understanding cause and effect here. Since the lower shock bushings have an inner steel sleeve that gets clamped tightly by the compression of the mounting bolt, there would never be any wear on the bolt.
The only way that I can think of in which a shock bushing would be destroyed after 5 minutes of operation, would be that the incorrect shock absorber is being used (resulting in the lower mount receiving the full weight of the vehicle during compression, or the full weight of the axle assembly during a rebound).
If you are getting aftermarket bolts, be sure the bolts have a hardness of 10.9.
  • John
The bolt has worn thin so the sleeve isn't tight around the bolt I fitted new shocks they started knocking a few weeks later. This was a few years ago now truck has been pretty much out of service until this summer. I will update the post with some pictures of the bolts.
Shocks I fitted was from rock auto as they ship fast to the UK and they would have been from the daily driver or performance section on there.
@Tractorman ignore that just looked the bushes look fine the knock is where the sleeve has play due to the worn bolts. 🤦🏻 It's been a while since I've gone through this truck.
Since using it this summer it's had:
New sills both sides 'rockers' in the us
Rear diff re-bearing
Service
Ac leak sorted
List goes on
These do not like sitting around for extended periods!
That makes more sense.
Since the sleeves have been loose for awhile, they probably have worn into the clamping "ears" of the mounting assembly. This will make it more difficult to achieve the right clamping force so that the steel sleeves don't move around after you install the new bolts. I recommend to closely monitor that clamping force for a few months after the truck is back on the road.
  • John
Yes I will keep a close eye on this it is on the road now just had an annoying knock over pot holes which are far too common over here. Especially with the amount of road tax we pay
