Working through miss/studder issues - codes 0237 & 0230
I picked up a 2000 Ram 2500 with the Cummins a few months ago. The PO said that he'd replaced the fuel pump a couple of times, which I should have paid more attention to. Ran fine though for a few months. Recently I had a big miss, or shudder under heavy acceleration onto a highway but ran fine for the rest of the trip. It happened several more times on later trips, usually at gradual acceleration. No CEL at that time. I did get the 0237 code, so got a new MAP sensor hoping that would fix it, but it didn't. I cleaned all grounds and harness connectors. Since then, a few test drives have been OK, with no missing, but even though I cleared the codes, they come back.
I have AutoEnginuity, so got the Chrysler enhancement package and found a few things. The MAP sensor checks out with 5.2V key on engine off. Test run yesterday, backing out of the driveway the voltage dropped to 4.93 briefly. Once going down the road, it stayed above 5V and responded seemingly correctly to acceleration. I suppose that the brief drop below 5V would be enough to throw a code. Let me know if otherwise. I haven't tried bending the diaphragm yet as described in a HOW TO DIAGNOSE VP44 FUEL SYSTEM ISSUES document.
Another thing I noticed was that the VP44 input voltage was dropping from 12.18V down to ~9V. Occasionally it would jump up to 13.5V, which is what I was measuring at the battery when it was running and the alternator was charging. 12.18V was what the battery read before starting. They were brief excursions either way, but it got progressively more frequent going down to 9V as my test drive went on. I can log and provide these charts.
The Banks tuner was unplugged during my testing, but was plugged in when I first started having the miss/shudder issue.
I thought I might be in limp mode, but I was getting boost pressures of 5-8 psi with just moderate acceleration on a test drive yesterday. Didn't feel too bad.
  • Replies 52
  • Views 6.7k
  • There is a single connector with two black wires that are connected to the positive post of the driver side battery. These wires supply power to the intake manifold heaters (grid heaters). Within a fe
  • You can just swap out another like fuse and another relay and go for a quick test drive. John
    On the Dodge FSM it will list wire colors and gauge size.
I would be looking into this before doing any parts replacing. Was the intake manifold heater post-cycling when you were seeing the voltage drop on your test drive. If you are not certain, then I recommend to disconnect the intake manifold heater to simply troubleshooting the voltage drop.
In normal operation, when the manifold heaters have finished their post-cycling, the voltage powering the VP44 should be steady around the 13.5 - 14.2 volt range. Steady is the key word.
If the voltage continues to fluctuate wildly at the VP44, then you should check the power supply to the VP44, ECM and the PCM; but more importantly you should check that you have good operating ground circuits.
  • John
Agreed. I cleaned all grounds I could find, using several references on where those grounds would be. There was a ground on the firewall near the ECM & PCM, as well as near that fender. I also disconnected those three connectors and sprayed them with Deoxit 5
I didn't check the manifold heaters, not knowing anything about them. I'll do the checks you recommend and post back, hopefully today. Thanks.
Sounds like you are on the right track.
The intake manifold heaters draw about 100 amps each - there are two of them. They are automatically in operation below 60°F ambient temperature. With the key on, engine off, the heaters are on while the "Wait to Start" lamp is lit. After the engine is started, the heaters post-cycle until a specific engine operating temperature is reached, or the vehicle speed reaches approximately 25 mph. The post-cycling current is higher than the alternator output, so it is normal to see the dash voltmeter drop significantly.
This is why I recommend disconnecting the intake manifold heaters while diagnosing a low voltage electrical problem.
  • John
Edited by Tractorman
I've tried to find the best way to disconnect the heaters, but am coming up short. I'm not sure I've identified the connections at the intake manifold, but am fairly certain they are the two large cable connections at the base of the air intake housing. I didn't think disconnecting those there would be the best idea. I traced them down to the solenoids, which I thought may be a decent option, but then figured that there was probably a fuse or relay in the fuse box that I'd be better off pulling. That send me looking for a fuse location diagram, but haven't found one yet. Searching this site and the Cummins forum had no luck either. Any recommendations on where to find this fuse layout? I do have the 2001 FSM, but fuse box wasn't in the index that I saw, and didn't dig deeper.
What's the best way to disconnect the heaters if none of these options are best?
When looking at the heater solenoids, I found that one of the four 90deg boot connectors on top of the solenoids was disconnected. I did miss the ground cable from the air intake housing to the manifold, so just cleaned those connections up.
There is a single connector with two black wires that are connected to the positive post of the driver side battery. These wires supply power to the intake manifold heaters (grid heaters). Within a few inches of the battery connection, you will see two fusible links - no fuses. Disconnect the the single wire connection.
There are two fuse group locations. One is called the Power Distribution Panel (PDC), and the other is called the Junction Block. The PDC is located right beside the driver side battery. Th Junction Block is located on the left end of the dash. The driver's door must remain open for access.
Hope this helps.
  • John
Cuz...
Test drove it just now. This was with the intake heaters disconnected from the battery. It seemed to run fine, but the log I've attached shows the IP voltage dropping and spiking as well as the MAP sensor (boost voltage) was dropping out.
Double check your fuse for the VP44 and the fuel pump relay in the PDC.
Fuse might appear good and be cracked which will give random drops of voltage. The relay connects might be bad too.
If you have the W-T ground wire mod. Then the ground for the VP44 is at the gear case otherwise the ground is the passenger battery terminal.
Use the wiring diagram and test the wires from end to end should have 5 ohms or less to pass.
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation/engine/electrical/2000-engine-wiring-map-r391/
Fuse #3 read good. I couldn't see any crack, but am not sure how I'd detect that. Similar with the R1 relay, although I haven't checked that one yet. I'll have to look into how to do that.
The W-T ground wire mod was done prior to me getting it. It all looks about the same as your Simplified writeup, but the alternator main wire still goes to the PDC rather than directly to the passenger side battery for whatever reason.
  • John
Cracked fuse will drop voltage randomly. Change with a fresh fuse t
  • John
Poor man's test it will work just remember you moved the possibly damaged fuse and/or relay so be careful of the systems you might affect. If you problem moves then the relay or fuse will need to be replaced.
I was wrong to say that I'd cleaned all of the major connectors. I didn't know about the ECM. Now that I do, I can still hardly see it. I see your instructions on how to remove it, but that doesn't go into any steps before that. I suppose that removing the fuel filter housing would be a mess on top of letting air into the fuel system. I read elsewhere that removing the battery and intake would help. Any recommendations?
My write up was more so for the tappet cover gasket replacement. The ECM has 10mm bolts holding it to the block/tappet cover. There is a single allen screw in the center of the plug.
I've decided to do some upgrades to my cables & connections before digging any deeper. Marine grade battery terminals should be in tomorrow. I need to get some more cable lugs though, because the kit I have is not up to spec.
The W-T ground wire mod was done prior to me getting the truck, and it had a splice with the 4 wires connected to a 10 or 8 AWG stranded wire. I didn't know the condition of the splice and felt the need to verify it. Once I got it open, it looked to be in good shape and was well sealed from the elements. I wouldn't guess that would have been the problem, but coincidence or not, the CEL went off on the test drive after redoing the connection with all 4 wires crimped in a lug and connected to the same ground location as the single lug was. I was still seeing spikes & dips in voltage as before though.
Problem is, I'm not confident in the long term reliability of my connection. The lug is bare copper, and the tab is thinner than a good one would be. I did solder the wires to the lug after crimping and put marine grade heatshrink over the joint, but I can't help think it is inferior to the wiring as it was before. I've seen mixed reviews about splicing though. Any recommendations?
You wrote, "I've decided to do some upgrades to my cables & connections before digging any deeper. Marine grade battery terminals should be in tomorrow."
Good plan!
Are you referring to ground splice 168 (top photo below)? If you are, then the W-T ground mod wasn't complete. This splice is disassembled and all wires are routed to the front gear case cover with an additional wire to driver side battery ground (see bottom photo).
  • John
Yes, that's the one. I thought the W-T mod had been done because the wiring going to the alternator had been modified, but I missed that they hadn't done the 4-wire connection. There is a 2nd wire coming off, but it goes to the ground on the top of the front corner of the fender (original location?), rather than the battery. I'll reread the W-T mod article again and try to get it all through my dense head.
I haven't cleaned the ECM connection or checked the wires yet, but there have been some changes. The log below still has the dips, but they're not random, excessive and short like before. Now the dips coincide with when I'm accelerating and getting boost. Truck ran fine.
I backprobed the MAP sensor connector had a Fluke 177 hooked up to that wiring, positive at the connector and negative at battery ground terminal. The meter never showed any of these dips. The slight increases at moderate acceleration did show on the meter. A mechanic buddy recommended I use the MIN/MAX feature since the digital MM might smooth out dips, so I did a run using that, and it never showed the drops down to just above zero. Min was like the shorter drops adove, at 0.321V. I also hooked up an analog multimeter, and it also didn't show dips to zero.
Regarding MAP voltages, I read that the values are supposed to be between 0.5V and something higher. I get 0.51V at key on engine off. Once I start, it frequently is dropping down into the 0.4+ range and staying down there a bit, although it doesn't look like it on the graph, other than the dips.
The CEL is still off. I have not run the dedicated ground from the gear case cover directly to the battery yet. It's still wired like in the post above. I need more terminal lugs to complete that.
Sounds like you are gaining ground.
If I'm understanding correctly, the engine is performing well, but you are still getting voltage fluctuations? Any codes?
  • John
Yeah, if it weren't for this log, I'd think all was well. But if my main diagnostic software looks like this, I'm not happy. I've not pushed it yet, though. Just traveling easy around local roads @ 45mph max. My 1st shudder, and it was a biggie, happened when stomping it on an entrance ramp.
Would have been easy enough to check codes when logging, but didn't. No CEL, so wouldn't expect any, other than the one that might show up because I don't have a stock lift pump, IIRC.
Is there a reference that shows what wire gauges are used? I'll need to order terminal lugs for each of the wires going to the battery terminals. I've measure OD of the insulation but don't know how thick the insulation is. I know the largest is 2/0, and think ground wires may be 10awg, but not sure. Not sure of the others.
