P1693 and P0121, Surging, dead pedal AND runs just fine
The purpose of this thread, at least in its infancy, is to document what is happening and my plans of action to fix it. I feel like its a 'rare' problem (in that I cant find another thread with the exact same issue), it is certainly unique!
As of the day of this rambling, the truck is just under 114k miles. 2001 2500, auto, stock, 4x4, loaded, etc..
Previously I had a thread wherein my grandpa still owned the truck and he was having the usual TC/OD issues. Never really did figure out what was causing that as the descriptions I had to work with were challenging at best, but I did the TPS signal wire TEE mod earlier this year, or whatever its called, from the TPS directly to the PCM and ECM. That fixed the TC/OD issue, plus it cleaned up the shifting. Definitely recommend that to anyone who hasnt done it!
Also had an issue with the cruise surging heavily pretty much all the time. I believe that was because of the hole in the vacuum line, some heat shrink over the tube fixed that up real quick.
But now, I am having an issue wherein the throttle just has a mind of its own occasionally. Typically only after the vehicle has been ran and heat soaked pretty well, or has sat for a minute, shut off, and restarted. It does not always act goofy and just randomly start accelerating once it is hot. It does it sporadically. At the same time, the throttle becomes EXTREMELY sensitive. No exaggeration, if you just move the pedal a millimeter or even just rest your foot on the pedal, the RPMs will get all sorts of goofy. Its pretty wild.
When the truck accelerates by itself, it will typically pop up a CEL immediately (P1693, which is actually a P0121), and occasionally the pedal will go dead after one of these episodes. Press the pedal a time or two, almost like a relearn, and it usually works fine for a bit. usually a half mile up the road it will do some goofy stuff again. This repeats until the truck cools for some time.
With the premise being set with the issue, I am fairly certain this is an APPS issue. This truck has not been ran hard ever. It has pulled 5th wheels, but RPMs were always kept below 2k. All that to say, I dont think its the VP. Truck runs great, plenty of power, etc.
My first action is going to be to install a spare Mopar APPS that I have (I want a TIMBO, but until I know for sure, it will wait). I believe it is the original, as G-pa had the dealer put on a new one back in, 2019/2020. I would have to check his records. I suspect that the APPS is the issue, so this thread might only be 3 posts long. If that does not fix the issue, my next step will be to monitor signal voltages while driving as well as APPS % in Torque and see if I can catch a discrepancy.
Feel free to follow as I keep my truck from driving off by itself.
  • Replies 6
  • Views 607
  • Timbo is a repackaged Williams Control. WC 131973/133284 is what they actually are.
  • Mopar1973Man
    It would be awesome to have a scan tool or Quadzilla to look at the APPS signal to see if its correct. At idle it should show 0% TPS. Which if there is signal above 0% with the Idle validation set the
Thank you for that info! Looking at some install photos, I see that is the case. Seems like Timbo has really good pricing on them, and thats with the harness. I assume he gets them from a real supplier and they are not knock-offs. Looking to get one here soon.
*QUICK UPDATE* (been sick, out of town, etc... the last 4 weekends!)
Just checked alternator AC voltage, was coming in between 0.045 and 0.050 volts. So I might need some diodes here sooner than later.
Verified TPS voltage at idle. It was fine, dare I say low. Came in at 0.46 so I turned it up to 0.3 below the spec on the back of the sensor. Verified function to make sure there wasnt any drop out or similar throughout the range, all seemed fine. I have a nice Fluke 115 with fast refresh and graphing, super handy!
Thinking this is a sensor giving out while hot. It has been cooler here lately and it hasnt been acting up as easily/often, which makes it tough to verify issues and repairs.
A new side quest is that the driver side flex brake line is leaking at the frame side crimp now, so I am going to order up some stainless lines to fix those up proper. This is after the fuel canister drain decided it no longer wanted to seal after being used a couple of times, got that fixed up with a OE Cummins part from Genos. Doing what I can to keep er goin, thats for sure!
  • 3 weeks later...
Another update
Purchased a TIMBO APPS and installed it. Drove truck about 100 miles on Sunday and had no issues with the throttle getting a mind of its own. It was warmer, mid 60s, and it has done it before in that temp range, so its looking promising that a faulty APPS when hot was the proper diagnosis. I have ran into that exact issue before with sensors and wiring, so if this repair holds, it really comes as no surprise.
Currently still waiting on brake lines to come in, they should ship this week or early next week.
We should start having 70+ degrees days in a couple months, so that will be the real test.
It would be awesome to have a scan tool or Quadzilla to look at the APPS signal to see if its correct. At idle it should show 0% TPS. Which if there is signal above 0% with the Idle validation set then hence the P0121. You not allowed to be throttling with the idle validation set. That new timbo apps should fix it.
I do have a way to monitor APPS, but I never really struck me to do so until I started this thread, and by then it wasnt doing it near so often, if at all. Now with the TIMBO installed, its just a matter of time to wait for the weather to warm and see if the issues persists.
  • 3 weeks later...
Quick warmer weather update.
Drove the truck out to the property, 26 miles and about 30 minutes one way, truck drove great and had zero issues. I found myself not even thinking of it acting up, just enjoying the old rig. Temperature was in the mid 70s and I even had a fuel stop in there with some time to heat soak everything, and alas! No issues! Hoping that this has fixed my issue and it seems to have!
One thing to note, and I dont know if this is a static setting issue or if maybe its a matter of a cleaner and better signal from the Williams TPS, this thing holds OD for a good while now. Which I like. Its enough difference that a passenger asked if the OD was on or off. Overall, shift timing has been improved again. Very very happy with how this is turning out!
