- Replies 7
- Views 1.2k
Tractorman 3 posts
Mopar1973Man 2 posts
PilotHouse2500 2 posts
Popular Days
Personally, I would keep the CAD unit in place. I did so and turned it into a 2WD / 4LO truck - very beneficial for slowly backing heavy loads in tight areas. I purchased and installed a vacuum so
@Mopar1973Man , the article is done. It is awaiting your approval. John https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation/transmission-transfer-case/low-range-2wd-cad-conversio
Awesome! Thank you much. It will be a bit till I get there, so I might have questions down the road. Excellent write up!
I'm considering deleting the vacuum and going with a delete kit locking the front differential. Has anyone done this? Anything that screams DON'T DO THIS?
