Building my own webserver
In all the years of being on hosting plans (GoDaddy, iPage, and Liquid Web). I have always had a premade server all set up for me. Yeah, I know hosting companies stamp these out quickly.
Since the home server has been up and running, it has done an excellent job of backing up data and doing basic tasks. I've got 32 GB of memory, 16TB of M.2 hard drives, and 16 CPU Cores. Now I'm installing the LAMP package (Linux, Apache, MySQL, and PHP). I'm using Webmin, Usermin, and Virtualmin for my control panel. So far, I've been doing well and getting things set up and ironed out on my own. I will admit that once you learn to use Google's AI features, you can diagnose a web server fairly quickly. Right now, the home.mopar1973man.com domain is only on the local server/network. This allows me to bench test all this server before hooking it up to the internet.
Now, in the study I've done, I found out I can still host data on the internet from my server even currently. As you see, the weather station here on the website is listed as Weather in the Mopar1973Man section. Then I've been able to check my security cameras. So this points out that there is something you can port out of the network here. From what I've found out, you can host data over Starlink, but you should have IPv6 set up and then have a full router, like what I've got here, a TP-Link ER605 gateway. The last step is to put Starlink into bypass mode. This should allow you to now control your data and port forwarding, which the Starlink box is missing. This keeps you locked out of doing something like hosting your own network on the internet.
home.mopar1973man.com will be the address of my server here. Currently, I'm not listing this on the DNS server yet. Security must be handled first. Second, since Starlink is a dynamic IP address its hard to lock a server to a moving IP address. Fix! My TP-Link SG2428-P Switch has functions for hosting a dynamic domain through companies like DnuDNS, NO-IP, etc. I opted for DynuDNS, which you have to set up using the Custom section of LAN DNS section. I forced the local machines to use the hosts file in Linux as a fake way of handling the domain name for testing.
Currently Ubuntu Servers are down due to hacker strike.
  • Replies 2
  • Views 630
I had a delay in my build of the server. The Islamic Cyber Resistance in Iraq 313 Team claimed responsibility for the attack on Ubuntu Servers. They have returned to operation state. I just finished updating both workstations for us and the server in under like 5 minutes. Easy as pie.
Quick script I built to handle this function...
#!/bin/bash
# A script to fully update Ubuntu and clean up system junk.
echo "--- Starting System Update ---"
# Update package lists
sudo apt update
# Upgrade all packages
# sudo apt full-upgrade -y
echo "--- Cleaning Up APT Packages ---"
# Remove packages that are no longer needed
sudo apt autoremove --purge -y
# Clear out the local repository of retrieved package files
sudo apt autoclean -y
# Remove all remaining package files from the cache
sudo apt clean -y
echo "--- Performing Deep System Cleanup ---"
# Clean up old journal logs (keeps only last 2 days)
sudo journalctl --vacuum-time=7d
# Remove old Snap versions (frees up significant space)
set -eu
snap list --all | awk '/disabled/{print $1, $3}' |
    while read snapname revision; do
        sudo snap remove "$snapname" --revision="$revision"
    done
# Optional: Clean thumbnail cache (Safe)
rm -rf ~/.cache/thumbnails/*
echo "--- System Maintenance Complete ---"
# Check if a reboot is required
if [ -f /var/run/reboot-required ]; then
echo "REBOOT REQUIRED to apply updates."
fi
System is secure again! Up to date and protected from hackers. I'm going to get back to getting the domain name working fully here in the house network as a bench test. I've never built my own server before, so this is all new ground for me and learning a ton of stuff about Ubuntu Servers. I actually like Ubuntu Linux its solid and well supported out there on the internet.
As for the server (LAMP package) I've got adjusting and setup to do yet through the webmin, and virtualmin.
Last night I got my web server here running... 😁
I know a lot of you might be standoffish about AI. So I was chasing the 500 error code I was getting. AI asked if I would look for errors between the Apache server and the PHP module. When I found the error, all I did was copy and paste the error message into the AI box and hit go, no other explanations. AI reported back that I was missing the PHP module "mbstring php module". Ask AI how to install, and it created a terminal command exactly what I needed, except for the version number. I told AI to assume PHP 8.3. So it created all future responses with proper version numbers. When I got the mbstring module in the installer screen started working instantly, and it showed the other modules missing as well. I was able to quickly install all modules and have a running copy of this software here at home. Only catch I screwed up my password and can't log in. (D'OH!) I'll just delete the install and install again fresh from the ground up.
This will provide my sandbox for the actual website and allow me to play without messing up a live site. Being my server here is much bigger than my hosting server I've got room for multiple servers.
Local Server (home.mopar1973man.com)
  • 16 core AMD Ryzen 5 7600X
  • 32 GB of RAM
  • 16 TB of storage (M.2 Hard Drives)
Live Site (Mopar1973man.com)
  • 8 Core Intel Processor
  • 8 GB of RAM
  • 160 GB Hard drive
Now with a bit of effort, I can create multiple virtual servers easily on my local server for different purposes.
Create an account or sign in to comment
