Engine Article - 2013-2018 Cummins delete kits
I bought a 2016 Ram Cummins 2500 Crew cab short bed Laramie 4x4 on May 30th, 2026.
Everything was working great until a week and a half ago, when my DEF reductant sensor started pegging empty or full repeatedly. I looked up the reductant sensor, and it was around $700. I figured that it was time for a full delete instead.
I bought a complete SPELAB delete kit for $1,224 shipped - EGR valve and cooler delete, DEF, DPF, and SCR delete, and it came with a H&S Mini Maxx V2 tuner for the delete tune, and that includes Tow, Performance, and Extreme tunes. Also, I bought their 3.5" intake horn and intake manifold plate (comes with its own coil grid heater) to delete the OEM grid heater. You will definitely need the IAT sensor extension harness too.
I installed the delete tune file first, as that is the recommended first step before removing any hard parts. I did that, and my check engine light for the DEF reductant sensor was gone. I ran the truck down the road to just check the Tow, Performance, and Extreme power tunes, and while I could tell they definitely modify the fuel and timing and added more power and torque. I decided to leave it on the "No Power" delete tune only. I already bought a like new Edge Juice with Attitude for the truck, so I was just going to use it for the power adder since I trust Edge tuning more than H& S Mini Maxx, since H&S has been out of business since the EPA heavily fined them in 2012 or 2013.
Next, I removed the OEM intake horn (which removes the EGR valve and throttle valve), intake manifold plate and installed the grid heater delete kit. The only real PITA for that, was removing the fuel injector lines to install the intake manifold plate. Other than that, it was a pretty straightforward install.
Then, I removed the EGR pipe and EGR cooler and installed the (2) EGR cooler block off plates onto the exhaust manifold. The 2nd block off plate comes predrilled and tapped for an EGT probe, which made it fast to install the Edge EGT probe.
I haven't had a chance to remove my DEF tank, DPF or the SCR yet, but the truck runs really good now. I just got my Edge Juice with Attitude and my cabin air filter and door installed yesterday, so I figured sometime this next weekend, the exhaust delete kit will get installed.
Full delete kit
Grid heater delete kit
View full Cummins article
  • Replies 3
  • Views 961
  • 01_Cummins_4x4
    01_Cummins_4x4
    Sure. I've been busy just fixing minor things on the 2016 Ram 2500 Cummins 4wd that I bought May 30th, 2026.
Would you be will to share your repairs as an article too? I'll even give you a $10 credit for each article we accept. Try to balance between a good amount of words in the page as well as good phots.
