Fass titanium 95gph fuel system pump motor replacement
Can i replace the 95gph motor with a 165gph. Its only like 12 bucks more.
Fass is closed but id like to order a motor tonight this one sounds kinda like the transmission with rocks in it.
I was cruising home today in 5th at 70 trucked buck so im thinking you peice of ****. Put it in 4th and stood on it cause im thinking you freaking pos trans.
Pushing throttle only made it buck and studder. Verifued **** i got no fuel and made it home to mtn home going 60 in fith. Truck stumbling pulling all the steep grades to mtn home.
Ughhhh ever werk so far having this truck is something. I did back on pump motor with a rachet and that only made it shut completly off.
I do have a airdog raptor spare but the fuel line are different because it doesnt have filters.
Thanks for any help.
  • Replies 2
  • Views 261
So i spent quute alot of time today on hold at fass also emailed them twice. Have a few hours into this with out success.
Figured out the rpt1005 fits my fass titanium directly of wich is discontinued
The rpts1005 is its replacement few upgrades whisper technology etc. These are 165gph units. The power connection plug might be differnt apparently fass changed plug 4 years ago.
Orderd rpt10005 through diesel performance parts i got my valair clutch through them.
The guys at diesel performance parts were very helpfull did some digging themselves to be sure that the rpt and rpts are interchangeable other than maybe plug.
Fass not so much.
Anyways thats all i got
Guess nothing on the truck will take a **** sitn in driveway waiting for pump.
So 165 pump dropped in place if 95 pump.
Pump kicks on truck runns smoother get in freeway hit cruise and lose fuel pressure wtf limp a few miles home she actually dies this time.
Roll off the side of road check pump fuse unplug fuel pump relay plug it back in cycle pump a few times wtf
Then crank no go cycle pump a few more times pump working again fffff crack two injector lines crank a bit then snug up line that pushed fuel.
Crank again she fires running on 5 hurry and snug last line slam hood hurry home.
Had about 20 people drive by thankfully noone stopped
Get home barely again pump silent at idle hmmm
So it was never a pump issue. I noticed when i turned key on pump didnt cycle but runs with truck idling.
Thinking relay so i go cycling key on my 02, pump cycles for a few seconds like it sposed to.
Yank relay off it and toss it on the 98 cycling key on pump comes to life then shuts off like it should. Wtf so i jump on free way get fuel etc jump back on freeway again. No issues now.
Fun stuff.
What will it be next . Everything on this trucks oem other than fass titanium.
Bought 60 miles to get to work tommorrow so well see.
