Won't shift out of 1st gear???? Help!!!
Just yesterday my truck stopped shifting out of first gear. It hold first as long as I'm accelerating but when I let off a little bit it sometimes shifts into second and then from there it's fine but when I come to a complete stop again same thing all over again. I'm new to this forum so I will fill out my sig right now.
  • Replies 7
  • Views 3.3k
Need to know what I am dealing with here. What year is it? Vehicle description and any add on mods stock tranny or aftermarket parts in it like VB or Converter or anything else. How many miles on it, when was last service oil filter change band adjustment?
Have to admit there has been no recent service at all. And no codes but a week before this happened everything was runnin fine and I piped a tps code so I just erased it and no codes since
  • 4 weeks later...
Travis;What have you found out on your trans issues?Mine is kind of doing the same thing, will not shift out of 1st with throttle on, but if I let up on the pedal or just drive easy she will shift to 2 nd and so on fine.The truck has 120K on it, trans has been serviced, no mods. Anybody have an idea to help??I was thinking a shift solenoid but????Thx Randy
