loss of mpg solved / no codes
- Replies 3
- Views 3.3k
Mopar1973Man 1 post
dorkweed 1 post
cmns2500 1 post
My truck has unfortunately had periods when I was unable to use it. (Multiple Sclerosis can do that.) Anyrate, although the truck seemed to drive ok and had plenty of power... even towed the trailer considerable distances... the mpg has been falling off serously. This has gone on for a couple of years and the truck has been through numerous state inspections, various mechanics & dealership. (The dealership said "no codes, nothing to fix!") The answer was found by accident at the most recent state inspection (a different mechanic) checked the front end and found the wheels would barely turn. The cause was two fold... the brake pads themselves were delaminating (although there was suffient material visible). Also the diameter of the disc had rust expanded so that it brushed the frame which supports the calipers. Any rate, a brake job brought the mpg back to the original mpg. The interesting thing is that the powerful CTD drove pretty normally with the brakes like that... although it is peppy and FUN to drive now!Russ
