- Replies 2
- Views 2.2k
Mopar1973Man 1 post
cajflynn 1 post
"In this case we found a way to get better fuel mileage and a little more power on some trucks. This pump has ALL the upgrades and improvements that our exact replacement units have." "What we did to achieve this goal was to mix and match parts from other VP44 pumps to advance the timing mechanically and optimize fueling rates for better mileage." "If you are presently or plan on advancing the timing with an electronic plug in device or programmer don’t buy this pump as we are only doing mechanically what those products do electronically. " "The Special X pump is made from all Bosch made parts. It does not have any aftermarket or modified parts in it, so this allows us to sell it with the Bosch 1 year unlimited mileage warranty." This VP44X pump seems to give 2-3 mpg improvement. Is it preferable to do this mechanically? Or to advance the timing electronically (which can be turned on & off electronically & alternative tunes utilized)? http://www.bluechipdiesel.com/bfmVP44.html Thoughtfully, Russell
