- Replies 6
- Views 2.1k
mrtowman4u 2 posts
jamman 2 posts
Mopar1973Man 1 post
MnTom 1 post
Hi guys,
I've been lurking and learning on many forums. I got my truck back in August of '10, but I've learned slowly along the way. I love the truck and know there are things I'm needing to do to it, but I got hurt and sadly it took a back seat to so many things and then other stuff came up. I'm trying to catch up.
I've got a leak inside that I noticed. There is a streak on the rear glass where it runs down. There is a little brown staining on the headliner on the passenger side. I don't know if there is a possible seam breach just back of the door on the roof, or if (in my opinion more likely) the cargo light that is on the back of the cab is leaking.
If the cargo light is the culprit, I assume that I get up there and unscrew it and repair the gasket. Is there a gasket? Do I clean off a sealant then go back with a silicone, rtv, or something? I'll try and put some pictures here to make this a bit more clear. I don't know if I have that privilege yet or not. Let's see what I can do.
Thanks for the help!
Jamman
'99 Quad Cab, Long Bed, 4x4, 6" lift, BHAF, EFX step rails, 140ishk miles
If you look, you can see a whitish trickle line down the entire glass. Follow that up and you should see some staining of the headliner.
This is an exterior view of the cargo light that I suspect is the culprit, but I don't know if there is a seam that I should worry about under that black plastic/rubber trim extending back from the door seam.
