Needed: Jeep Grand Cherokee Instrument cluster wiring diagram
I'm working on a dash cluster issue for my neighbor. He bought this JGCL from me a couple of years ago, and I do most of the maint./repairs for him. At any rate, I'm trying to find a wiring diagram for it's instrument cluster. Not sure if it's bus-fed or what.. The cluster is modular and plugs into the dash plug, rather than multiple harnesses loosely plugged in. The plug is singular and I think it's 10-wire connector. I need to know what the wiring pinout is.Any help is appreciated. The 95 wiring diagram is not the same.
  • Replies 12
  • Views 24k
Ummm... It would help to have some make/model/year information... :shrug:From what I can find really quick and guessing at year and model I see that its CCD network feed.
I failed. Lol1997 5.2LSent from my rooted EVO's tiny keyboard with my opposable thumbs...
And title states make/model ;)Sent from my rooted EVO's tiny keyboard with my opposable thumbs...
Thanks Mike! Where in the heck did you find it? LOLThe unfortunate part is, the light control I'm looking at is BUS fed.. :(
you are definitely "the man" :)
does your bag of tricks show where the ABS control module is located? Or is it integrated into the pump? My scanner fails the ABS section with "No Communication with ABS Module"...
so... the CAB module (controller, antilock brakes) is bolted to the bottom of the pump assembly. Dodge wants $1000 for the control module, and $1200 for the pump (or controller).. So $2200 for both pieces! W.T.F.??@Mike - happen to have the schematic for the ABS controller for same '97 Grand Cherokee? ;)Impress me LOL
Thanks, Mike! Exactly what I needed!
  • 2 years later...
I need this same diagram for a 1996 Jeep Cherokee Sport. All of the insturments are off. They randomly flash on. I'm pretty sure there is a loose or broken ground but I don't know which pin on the instrument cluster is ground. The dash lights and the idiot lights work but the guages are all off.
