- Replies 14
- Views 3.6k
2500ctd 5 posts
dieselautopower 3 posts
AH64ID 3 posts
silverram323 2 posts
In the quest for more power, Current plan is try to find a s480, not much luck, Thoughts of a supercharger always take top honors, even if just casue it looks cool.
On the other forum with the superchargers, a previous setup he ran was triple turbos. Basically splitting primary turbo in half. More or less.What about using one of those 351 variable turbos parallel with my turbo. The vgt should spool quick get it going and then the bigger turbo will catch up, then the combined turbos would equal a big single that wouldnt normally be able to be streetable in a DD. Some high end cars have sequential turbos, but I am not sure if the other takes over completely or if they run in unison. I would be worried about the quicker spooling turbo pushing air back through the slower spooling turbo.Just an idea, havent put a lot of time into research but it got me interested.
