undercoating
Im thinking about undercoating the frame rails on my truck. Has anyone else done this?
  • Replies 27
  • Views 20.2k
I am not quite clear on this. Are you saying that they added K1 to the wash water when washing the truck?
That was what I ment to write.
The K1 would strip any wax of the truck, otherwise I would try that.
It's an oil. The wax I use says it can withstand acid rain so a lil K1 or D2 w 2-3 gal of wash soap & water? Aren't most wax products petroleum based? It's really to help fight the salt & road chemicals, if that doesn't take off wax! Just passing on old timer info is all. As far as new products go, I'm having nice results w the new wax a you dry products out on the market. Everyone I've tried works good. I still like to hand wax too, but these new products help enhance the shine. Dave
I don't know if they are petroleum based or not. However, I based my [assumption] that K1 would strip wax, upon the use of Mineral Spirits to strip wax, which is a standard means in woodworking for wax removal. I am sure I am probably wrong, "as usual". It is my experience that waxes today are ALL over rated regarding how long they last. I do know from my own personal experience that dishwashing detergents like Dawn or Polmolive really strip wax when used to wash a vehicle. I have waxed my truck, and in one wash with Dawn dish detergent the wax was totally gone. It sure does clean the bugs off nicely though and when I want to get my truck really clean, like when it has that Calcuim Choride on it (used for ice melt on the roads in Maryland) I use Dawn and then try to get some wax on it right after that.Regarding acid rain. I live in a particularly bad area for that and the waxes I use (Meguire's, Norton ect.) are good quality waxes but haven't been able to overcome that acid once the sunlight hits those water droplets.I hope I didn't come off wrong about the K1. You have my interest now, and I will give it a try and see how it works. The older I get the more I realize that the things that the generations before us did were simple, yet worked, and were generally cheap. ie. ammonia, for cleaning interiors, Vinegar/water and a drop of soap for windows ect..Simple is good. Thats why I have a 24 valve Cummins. The more I learn about the simplicity of this truck, the more I wish I had bought one years ago.
RJC,I know what you mean about simplicity of a CTD, esp a 12 or early 24V. I do as well wished I bought one years ago. Mine almost gets the mileage my 4cyl 89 DaKota 5sp used to get. Is the CTD a workhourse. I really enjoy mine.Keep your truck clean, almost all the gen 2's are rust buckets up here in NE Ohio. Wheel wells, doors, rocker panels, fenders.I will re-oil mine before winter. Got my sprayer from harbor freight, just an air gun w a draw tube. I use the oil I drain out of my truck. Make sure it's at least room temp & turn up the pressure on your air compressor.Dave
The oil spray is a really smart thing to do, especially where you are located. The vehicles I have seen from your area look like Pennsylania vehicles do. I wish Dodge or Ram or whatever they are called now would get their act together with the quality of the body build. If they had given attention to this ten or twenty years ago they would have built a really good reputation by now and wouldn't have to sell their trucks for $8,000 less than the other two.
