Help wiring fuel pump delay relay
- Replies 3
- Views 6.3k
Mopar1973Man 2 posts
slowpokedodge 1 post
Hi all, I am new to this forum but have posted on the cummins forum. I got a 98 24 valve with the hard start problem and need some help. The parts store charged me 17 dollars for the 11 dollar relay. I didn't get a socket with it, is it ok to attach the wires directly to the relay or do I need a socket. Can I just trace the yellow white wire back from the lift pump and cut it and attach to the relay. I have looked at the schematic that moparman provided. I see that pin 86 goes to ground and 85 ties in with the brown starter wire, can I trace the wire from the starter up and tie in anywhere? The yellow white wire must be cut and connected to pin 30 and 87a. Sorry to ask some stupid questions but it cost a lot to take it and have somebody else fix it. These are hard times for the working man.Thanks for any help!
