How much would this cost ? or worth
1998 Dodge Ram 3500 2WD 5 speed manual with the 12v cummins ( not cummings ) 149k miles regular cab 8ft PTO heil dump body with the L tool boxes behind the cab
Drives well tires are maybe 10k miles old or so new exhaust clutch is strong brakes are good just got a little of a valve cover leak on the exhaust side and the oil pressure switch is gone bad it keeps going up and down and trips the check gages light horn dont work either but thats should not be a big deal to fix
Doors are not rusted as well as the rocket panels it even still got the paint on it, under body is cleaner than 100's I seen before only thing rusted is the metal mounts on the bottom of the seats but its surface rust nothing too bad the floor is still solid from top and bottom I pushed on it with a screw driver and it didn't budge
can I plow with it if I have to ? or just dont waste my money on a plow ?
how much you think its worth ?
  • Replies 15
  • Views 4.2k
I'm gonna say around 8k since it has a dump bed. If you can figure out a way to get traction then it would be a better plow truck than a 4wd since you don't have to worry about the transfer case or front axle.
I thought I was too low with a 10k offer including NJ taxes ( 7% ) they asking $11k Plowing is not really my main issue I have my 2500 cummins 4x4 to plow this would be fall clean up and firewood delivery truck for my landscaping business and if I can maybe put a salter on the back for some extra business.
I don't know about 11k. 8-10 is probably reasonable. I guess with the tool boxes and stuff he wants a little more. Yeah, 8-10, nothing more.
Yea I have to stick below the 10k mark anyway
I haven't had a plow on a truck... However I do live in very snow prone areas. I doubt 2WD would do much with a plow. As a matter of fact, I wouldn't want to do much serious driving with 2WD without chains if it gets too ugly. And if its that bad, chains may tear up any pavement or road base.
how hard to change a valve cover on the 12v ? I have done some Honda and Nissan before nothing too involved what about the check gauge light and oil pressure that's a pressure switch gone bad right ? Do I have to change the valve springs !
The valve covers are 10x easier than the 24V ones because they are individual. The big plate thing that says 12V on it is taken off with 2 screws that you will see, then you can throw that thing off and see each valve cover, each has 1 bolt and then it comes off. They each have a gasket under them. My oil pressure is doing the same thing right now, the oil pressure sensor is under the injection pump and above the power steering pump right in the side of the block.
sounds like its easy to do my self
I would agree with around 8k, can you post a few pics of it? That would help with pricing it as well.-Jordan-
Here is a picture I snapped when I went to test drive it yesterday
And this one is from the listing online
It's so simple I just went out and made a video to show you.
Wow that's great I think it was harder to open the hood and find the right socket than taking the cover itself off :lmao: :lol:Thanks I really appreciate your help :thumb1:
I got a brush guard that leaves no access room in there so you gotta push the latch and push the hood up with your fingers (when using one hand), I didn't get it up far enough lol. Let me know if you need any other vids, seriously, I can make them and put them on here so easily and quick it's not even funny :lol:
