Truck dead posted a couple weeks ago, got time to dig
OK I got time to do some digging to update I was driving down the road and it died would restart only idle rough no thottle response, but after starting four times doesn't idle anymore. Codes were 1688/1689OK 20 psi going into the pump, fuel spits out at injecter line( don't know how much) put a different injecter pump in that I had and it still is the same way it was after it died. Cleared codes and none have came back. Any ideals where to go next, thinking start at the batterys and check every connection I can, will have to take to a dealer next don't know where to go. Thanks for the help:banghead:
  • Replies 3
  • Views 1.5k
Well lets work with last known codes...
P1689 - No Communication Between ECM and Injection Pump Module
Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
Monitor & Set Conditions
Communication between Engine Control Module (ECM) and fuel injection pump module is monitored when
ignition is on. Injection pump module is referred to as Fuel Pump Control Module (FPCM) in test procedures.
DTC may be stored if the time between CAN messages is more than 3 seconds or FPCM does not receive CAN
message.
Possible Causes
[*] Wiring & Connectors
[*] Fuel Injection Pump Relay Output Circuit Open
[*] Ground Circuit Open Or High Resistance
[*] Datalink (+) Circuit Open
[*] Datalink (+) Circuit Shorted To Ground
[*] Datalink (-) Open
[*] Datalink (-) Shorted To Ground
[*] ECM
Testing
1. Turn ignition on with engine off. Using DRBIII® scan tool, check for DTCs. If Good Trip Counter for
DTC P1689 is displayed and not equal to zero, go to next step. If Good Trip Counter for DTC P1689 is
displayed and equal to zero, go to step 3 .
2. Turn ignition off. At this time, conditions required for DTC to be stored are not present. Inspect wiring
and connectors between FPCM and ECM. FPCM located on top of fuel injection pump. ECM is located
on driver's side of engine, just in front of fuel transfer pump and contains a 50-pin connector. If no
problems exist, go to next step. If any problems exist, repair wiring or connectors as necessary.
3. Ensure ignition is off. Disconnect FPCM harness connector. FPCM harness connector is located on end
of fuel injection pump. Check for poor connection/terminal contact at FPCM harness connector. Repair as
necessary. Turn ignition on with engine off. Using DVOM, measure voltage between ground and terminal
No. 7 (Red/Light Green wire) on FPCM harness connector. If voltage is 8 volts or greater, go to next step.
If voltage is less than 8 volts, perform DTC P0215: FUEL INJECTION PUMP CONTROL CIRCUIT
test.
4. Turn ignition off. Ensure FPCM connector is still disconnected. Disconnect ECM harness connector.
Check for poor connection/terminal contact at ECM harness connector. Repair as necessary. Connect a
test light between battery voltage and terminal No. 6 (Black/Tan wire) on FPCM connector. This is the
ground circuit for FPCM. If test light illuminates brightly, go to next step. If test light does not illuminate
brightly, repair open or high resistance on Black/Tan wire between FPCM and ground connection.
Ground connection is located at ground connection for negative battery terminal.
5. Ensure ignition is off and FPCM harness connector and ECM harness connector are still disconnected.
Using DVOM, measure resistance of White wire between terminal No. 2 on FPCM harness connector and
terminal No. 13 on ECM harness connector. If resistance is less than 5 ohms, go to next step. If resistance
is 5 ohms or greater, repair open or high resistance in White wire between FPCM and ECM.
6. Ensure ignition is off and FPCM harness connector and ECM harness connector are still disconnected.
Using DVOM, measure resistance between ground and terminal No. 2 (White wire) on FPCM connector.
If resistance is 5 ohms or greater, go to next step. If resistance is less than 5 ohms, repair short to ground
7. Ensure ignition is off and FPCM harness connector and ECM harness connector are still disconnected.
Using DVOM, measure resistance of Black wire between terminal No. 1 on FPCM harness connector and
terminal No. 23 on ECM harness connector. If resistance is less than 5 ohms, go to next step. If resistance
is 5 ohms or greater, repair open or high resistance in Black wire between FPCM and ECM.
8. Ensure ignition is off and FPCM harness connector and ECM harness connector are still disconnected.
Using DVOM, measure resistance between ground and terminal No. 1 (Black wire) on FPCM harness
connector. If resistance is 5 ohms or greater, replace and program ECM. See appropriate REMOVAL,
OVERHAUL & INSTALLATION article. If resistance is less than 5 ohms, repair short to ground in
