- Replies 6
- Views 3.4k
Mopar1973Man 2 posts
rburks 2 posts
cajflynn 1 post
keachman1 1 post
O.K.... Trans. starting acting weired, 3-4th gear hunt last week. i recalibrated the APPS and it fixed it, then Last Night coming down the Parkway cruising at 70MPH it started what felt like either jumping out of 4th Gear or TQ unlocking only for a split second, I MEAN IT WOULD ONLY DO IT SEAM LIKE WHEN I WOULD VERY SLIGHTLY DECREASE PRESSURE ON THE PEDAL. It would only last for a split second...... Done the key trick this morning and got "122 code
But here's the thing, I just replaced the APPS with TIMBOS 8-months ago. I remember that at first when i put the volt meter on it following Tims instructions on adjusting free travel my orginal voltage was way high over what the instructions said it should be. and even after talking to Tim while doing this We could not get it down...he eventualy said not to worry, just adjust the screw until voltage increase's and back it off..
Could it be the APPS
Richie
