is there a kit to lift the rear 2".I did the 2" level kit ,the front seams higher than the rear now
  • Replies 7
  • Views 1.7k
go too your nearist spring shop and get a couple of higher blocks for the rear
Thanks!! I check with the spring shop for higher blocks
Just remember that the taller the block, the more fulcrum advantage the axle has on the spring packs, and the better the chance of spring-wrap under torque loads. (i.e. advancing the spring fatigue) Adding a properly made leaf to your existing pack is the best way to do it, IMHO.
good point, but most guys want the hight not the stiffer ride
..until they wrap the driveshaft out of the t-case, then wonder WTF just happened :lmao:
Somebody mentioned the best is air bags ,this way you have better control on the ride & load
