To all; I have been having trouble with my 2000 2nd Gen, The truck was shifting strangely, I was getting what I thought was "dead pedal". I perused the board for answers to others questions/posts. I could not get more than the 1693 code from the odometer readout...no matter how many times I did it...sorry Michael, I just couldn't get it!So far I have done the following, and the problem comes and goes.1, I removed and cleaned ALL the grounds in the system, and the battery leads, and the fuse/relay box leads2, I have replaced the Carter pump with a Fass replacement pump, just because and I have 153000 on the truck3, I have replaced the APPS with one from Timbo. 4, Today I went down to my local Autozone and had them pull the DTC codes from the truck ( I know I should have done that first! ) The DTC codes from the truck were P0236, and P0237, which are for the Map sensor, Turbo over boost and under boost.Can it really be this simple? I read somewhere that the Map sensor can be cleaned, is this so? I thought I was looking at a VP44 failure.Can anyone help me with this? Don't hesitate with your suggestions, please. Thanks Randy
  • Replies 19
  • Views 4.6k
Well, I removed the IAT sensor and the Map sensor and cleaned them as Michael instructed in the tips section they weren't very dirty....no difference in the way the truck runs....still like it is 1/2 power..or less.I saw there was a resistance test for the IAT, is there a test for the MAP sensor, should I just purchase a replacement? Is there a better aftermarket one or should I go OEM?Help....I need my truck back................R
Sounds like a typical MAP sensor failure, I would not bother cleaning it at this point. Just replace it with another, should run you about $60 from Cummins and doesn't take long to replace.
If I change the Map sensor out will the codes clear by themselves or do I have to get a reader to clear them?What would be an good fairly economical code reader to have ?? Thanks
MoparMan, Do you have a lead to which code reader I should look for, and a recommendation for same? Randy
Here is what I'm using and love it... work really good... http://www.scangauge.com
I have no expierence with the scangauge but have been looking at purchasing one since my overhead is full of itself. Walmart also carries simplistic OBD II code readers that will work for this purpose.
I should have the new Map sensor today from my local auto parts store, hope this takes care of it!! Will install it and clear the codes, see what happens???? Randy
It would but they don't allow for Live data stream viewing like the ScanGauge does...
Hmmm.... That's odd... Most parts stores can get the MAP sensors for Cummins... Verify it closely before you buy it...
They had to reorder it from another distributor...the computer lied and said it was in stock.I hope it comes in today and my truck will run like the other 3 cylinders are workin !! I will let you know
EUREKA !!
I picked up the Map sensor from my local parts guy, installed it and cleared the codes, And presto-chango my truck was HEALED..........Now I can hook up the programmer and get back to the way it's supposed to drive. Thanks for all the help and advice from all :thumbsup
Now! How would I best get a little more power out of the old girl? I have the following done.
1. Replaced the air filter with a cone type high flow (not a K&N) I had an amsoil filter and thought I would try this one.
2. Bully Dog programmer. Simple 3 step, 65hp on high I think.
3. Expandit 5" pipe system w/floe thru muffler
4. Rebuilt Trans w/shift kit, HD Converter, bands ect.
Where is the best place to get some guages?
Trans Temp, ect
Mopar, I have heard a lot about different guages to use, not diff mfg's, When I order my piller mount I will only be able to mount 3 guages I think?I tow a camper so I know I want a Trans Temp guage, I am also thinking of installing an aftermarket trans cooler w/fans. What would be the other two that would be most important?Pyro, pre or post?Turbo Boost?Other? Thanks R
Mopar, I have heard a lot about different guages to use, not diff mfg's, When I order my piller mount I will only be able to mount 3 guages I think? I tow a camper so I know I want a Trans Temp guage, I am also thinking of installing an aftermarket trans cooler w/fans. What would be the other two that would be most important? Pyro, pre or post? Turbo Boost? Other? Thanks R
Order of importance... 1. Fuel pressure (0-30 PSI) - Without a fuel pressure gauge you can ruin your VP44 injection pump. 2. Pyrometer (0-1,600*F) - Without a pyrometer and towing you can exceed 1,200*F rather quickly even with a stock engine... 3. Boost pressure (0-35 PSI) - Good to keep track of the boost has a direct bearing on Pyro Temps. 4. Trans Temp - Protect your trans from overheating... I don't hear of many problem in this catagory... You can order a 3 place a-pillar and a steering column single pod.
Ok, I finally bit the bullet and ordered the gauges for my truck from GOS with the pricol gauges, I have not bought a fuel pressure gauge as of yet. I have went and used a pressure gauge at the port on the VP44, after replacing the lift pump with a fass replacement I have 30lbs of pressure after starting the engine. Is this too high, or ok?Is there a gauge mount for the steering column? I have not found one yet. Thanks, Randy
I was afraid that the fuel pressure would be low, so I installed the heavier spring with the new fass pump :red . I suppose I should take the pump back out and put the stock spring back in `:( ????Will the higher pressure really hurt anything? The truck seems to run fine........... :confused
Here is the factory fuel pressures...
Posted Image
It might cause hard starting issues... But there is a thread over at CF.com about high fuel pressure.
http://www.cumminsforum.com/forum/98-5- ... ssure.html
  • 7 months later...
Either my FP sender is going bad or I need to change my fuel filter because I cant get over 10psi idel on mine. Around 5-6 psi WOT. :banghead:
