2nd Gen power issues
- Replies 19
- Views 5.2k
randy4140 9 posts
Mopar1973Man 7 posts
cummins2k 2 posts
Cummins2001 1 post
To all; I have been having trouble with my 2000 2nd Gen, The truck was shifting strangely, I was getting what I thought was "dead pedal". I perused the board for answers to others questions/posts. I could not get more than the 1693 code from the odometer readout...no matter how many times I did it...sorry Michael, I just couldn't get it!So far I have done the following, and the problem comes and goes.1, I removed and cleaned ALL the grounds in the system, and the battery leads, and the fuse/relay box leads2, I have replaced the Carter pump with a Fass replacement pump, just because and I have 153000 on the truck3, I have replaced the APPS with one from Timbo. 4, Today I went down to my local Autozone and had them pull the DTC codes from the truck ( I know I should have done that first! ) The DTC codes from the truck were P0236, and P0237, which are for the Map sensor, Turbo over boost and under boost.Can it really be this simple? I read somewhere that the Map sensor can be cleaned, is this so? I thought I was looking at a VP44 failure.Can anyone help me with this? Don't hesitate with your suggestions, please. Thanks Randy
