Tryin to figure out where stock lift pump is at
Hey guys need some help. Does anyone have a picture of a stock lift pump or explain to me where its at. Im trying to figure out if mine is on the motor or in the tank. I turned the key on to listen for it and I didnt hear anything which might not be a good sign. I know the general area of where its at. Its below and behind the fuel filter housing if its still on the motor. I've seen two things that could be it. One is horizontal with the ground. It has a red chrysler sticker on it but i could read it because of dirt. The other is mounted vertically. Any help is appreciated
  • Replies 3
  • Views 1.6k
Posted Image You see the fuel filter, then off to the right you should see 3 silver nuts, that is where the fuel pump is located in the stock position.
Try bumping the starter without starting the engine. It should run for 25 or so seconds and you should be able to hear it running. Unless it is not wired to the ECM.
Thanks for the pic stodg73, I found the three nuts under my hood. Glad its on the side and not in the tank. dripley, I am going to do that at lunch just to be sure because the ad100 is getting ordered this afternoon.
