Injection pump gear removal problems
- Replies 9
- Views 5.7k
ISX 3 posts
mr.mindless 3 posts
bjytech 1 post
rdsutton 1 post
This past Saturday I was planning on taking my injection pump off so that I could replace my tappet cover gasket since its leaking pretty good, but I could not get the injection pump gear to budge. I took the nut and washer off the shaft then put my puller on it and all I managed to do was bend the steel plate part of the puller and one of the 10.9 hardness bolts, the gear did not move at all. So I am at a loss of what to do next, did I miss something? or is my gear just really stuck on there?
