Transmission Question
Just got my truck back two days ago from tranny rebuild. I went to pull out with trailer today and make around 25 miles to fuel station. Tranny temp @ 195*, gears are not catching when putting into D,3,2,1 or R. I shut the truck off and turn it back on and it would make it maybe twenty ft before doing it again. I searched for codes and received the P0500 can this have anything to do with the tranny issue? I know what the code stands for. Thanks for any help
  • Replies 2
  • Views 2.2k
As far as the P0500 code most likely not... Sound like you should contact the tranny shop that did the work somethings not right that's for sure...
Hey, :agree: Sounds like something didn't get put together right!!!!! :mad I would let them pay for fixing it, not you trying to throw money and time at it!!!!!! :thumbsup Good-Luck, Winslow
