Any welders in here?
- Replies 9
- Views 2.6k
02cumminsdude 3 posts
bh115577 2 posts
jlwelding 1 post
dually 1 post
I figured I'd post up here since many of you guys seem very knowledgeable on many subjects. But I'm looking into getting some type of welder, preferably MIG, something fairly easy to use. I have not welded since high school and that was fairly minimal. But I've got a few projects planned that need to be somewhat customized. I may not even be able to get everything I need done with ONE machine, but if I can wing it, I'd like to. I need something that I can use for something as heavy duty as welding steel to steel for adding some boxes, rack and hooks to my work truck ladder rack. So obviously I need something that will make a decent weld for safety reasons. I also need make some custom sized water diverters for my job out of a thin sheet metal. Other various projects would be small exhaust tacking or other light duty use. If I had to guess at this point, material thickness will vary from probably about 1/8" to 1/4", but it's possible the diverters I'm making are slightly less than 1/8" thick. So basically, (if there is such a MIG type welder) I need something that will tackle a various amount of projects in one unit. I've seen some of these electric welders that have the option to attach a fuel source to it if needed, but will also work on electricity alone. I just don't know what brands are good or bad. Money is also somewhat a problem after everything I've spent on my truck recently, so I need some affordable suggestions as well. Thanks for any ideas
