I have gotten this a couple of times, unplug the main connector inside and reconnect it clears up. All grounds look good. What can I check?
I am here: http://tapatalk.com/map.php?5zlayk
2003 Ram with gauges and a Smarty! Not much more.
Sent from my iPhone using Tapatalk
I have gotten this a couple of times, unplug the main connector inside and reconnect it clears up. All grounds look good. What can I check? --- I am here: http://tapatalk.com/map.php?5zlayk 2003 Ram with gauges and a Smarty! Not much more. Sent from my iPhone using Tapatalk
