electrical issues again.. ugh
- Replies 5
- Views 2.3k
cumminapart 3 posts
Mopar1973Man 2 posts
Okay awhile back maybe 20,000 miles tops I replaced my alternator and all was good.....Well except 3 random times when the truck just completely shut off beginning with the radio and everything turning off followed by the engine dieing a second later. Everytime it cranked over and started right back up no problems.Now today i lost charge... gauge went all the way down to nothing and the check gauges light came on.After driving home I shut it off and turned it back on... the voltage read around the 12v mark as I believe it should if it is just pulling off the batteries but not charging.I took the alternator off and had it tested... they claimed it was bad and though skeptical I got a new one which didnt change anythingI cleaned all the battery terminals and had the batteries tested.. both checked out goodNow I am at a losspossibly time for a new PCM? I realize that it could be just about anything when it comes to electrical though.
